I received a request to have 2 VIP addresses (2 virtual servers) that will have the same pool, the pool will have 2 members. The part I am unsure of is that the pool will need to really use one pool member at a time.
VS of 192.168.15.10 and 192.168.15.11 listening on 80 or 443 not sure yet.
pool 192.168.11.5 port 443 or 80 192.168.11.6 port 443 or 80
We will only want traffic to be sent to 192.168.11.5 however 192.168.11.6 the server will be up, waiting in standby. I guess my question is will f5 need to mark 192.168.11.6 down not to load balance to it because it is in the same pool, and then come up if 192.168.11.5 goes down? I am thinking maybe a specific monitor on 192.168.11.6 that would bring 192.168.11.6 up and make sure 192.168.11.5 is down.
The active/standby condition can be accomplished by enabling “Priority Group Activation” and selecting “less than… 1 Available Members” in the pool members pane properties. On pool member 192.168.11.5, assign a priority of 2. On 192.168.11.6, assign a priority of 1. As long as 192.168.11.5 is healthy, the LTM will only serve connections to it. If it gets marked down, the LTM will serve connections to 192.168.11.6 (assuming it is available).
As for the https/http issue, you can have one VIP that terminates SSL, and another VIP that listens on port 80. They both can send to the same pool using port 80 (or whatever you want). It all depends on your particular use-case. For most of my websites that serve https, I have the 2 VIPs described above, but the port 80 VIP does nothing more than send a 301 redirect to https (via iRule).
