We have Big-IP version 13.1. When I try to create local traffic policies, requires and controls fields are missing, as it is described in the guidelines. I’m unable to create any rule. Here is the screen shots:
All the way to your right there are plus (+) signs which are used to create new conditions or actions. Is that what you are looking for?
Also, The GUI for LTM policys in 13.1 has some major bugs, so be very careful when editing a rule that you have previously made since the conditions might not be shown correctly. We’ve reported it and it is confirmed as a bug.
Hello giokupra,
Unless I’m mistaken, these fields are not used in version 13. You can create your rule directly by adding your Condition/action… What rules do you want to implement? I will help you.
regards
