kgaigl
1
Hello,
One of the Monitors shows in the “Instance”-tab no pool but some of the nodes.
Also the Server Admin told me, that the Healthchecks ate still running.
I know I recently did some changes in monitoring but if I change the monitoring of a pool, the the old monitor is not in use.
The Nodes have all standard-settings, no special monitoring activated.
by chance, I’ve uploaded a qkview to ihealth (for another Reason) and the affected Monitor is not in the List of Unused Objects.
Any Ideas where to look?
Oh, Version is 14.1.4.4
Hello kgaigl.
Use this next command (from bash) to figure out what objects are using this monitor.
tmsh -q -c "cd / ; list recursive one-line" | grep <monitor_name>
kgaigl
3
Hello Dario,
thanks, I found a Pool and I’m wondering, why in Monitors → Instances the Pool is not listed.
But thats at the moment not our Problem:
On Monday after the Problem I switched to the Standby BIG-IP and rebootet the Active One, but the BIG-IP fails to reboot (Restarting Tomcat) ☹️
opend already a Support Case
Yep, something this happens 🙄
BTW, please don’t forget to give some thumbs up or mark the response as “resolved” to let other users find it.
