LTM monitor listing TMSH
Hi
In the manual i read:
tmsh list /ltm monitor http_new
This works fine for the native monitors, but when i do the following:
tmsh list /ltm monitor Exchange_2010_imap4_monitor
all i get is:
Syntax error: “Exchange_2010_imap4_monitor” unexpected argument
I am probably doing something wrong, but what?!
(Ah yes, the monitor does exsist in the GUI and is operational)
TIA Erik
e.g.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor Exchange_2010_imap4_monitor
Syntax Error: "Exchange_2010_imap4_monitor" unexpected argument
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor imap Exchange_2010_imap4_monitor
ltm monitor imap Exchange_2010_imap4_monitor {
    debug no
    defaults-from imap
    destination *:*
    folder INBOX
    interval 10
    time-until-up 0
    timeout 31
Hm that’s not working either i’m afraid. Did i mention this is an external monitor?
[root@wg-thei-lb01:Active] config tmsh list /ltm monitor imap Exchange_2010_imap4_monitor
01020036:3: The requested monitor template (/Common/Exchange_2010_imap4_monitor) was not found.
[root@wg-thei-lb01:Active] config tmsh list ltm monitor imap Exchange_2010_imap4_monitor
Did i mention this is an external monitor?so, what about “external” instead of “imap”?
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor external Exchange_2010_imap4_monitor
ltm monitor external Exchange_2010_imap4_monitor {
    defaults-from external
    destination *:*
    interval 5
    time-until-up 0
    timeout 16
