LTM Maint. Page issue
All -
I am trying to set up the LTM Maintenace Page example and I’m running into an issue. I have set up the rule exactly as described in the document (http://devcentral.f5.com/Wiki/default.aspx/iRules/LTMMaintenancePage.html).
The issue I am having is that instead of the lindex html stream being returned, it is returning the location of the class file to the browser. When I invoke the rule by going after the VIP from my browser, the only display I get is:
/var/class/maint.index.html.class
Thats it! It seems like either a variable isnt being invoked correctly, or for some reason it is interpreting the call to the class file as a literal.
My iRule reads like this:
       Service requests for files (URIs) from the maintenance page
       Note that we always service these pages, even if the http_pool is up
      set maint_prefix "/maintenancepage"
      set maint_len [string length $maint_prefix]
      set uri [HTTP::uri]
  log local0. "redirect: [HTTP::uri]"
  if { $uri equals ${::maint_prefix} } {
         HTTP::respond 301 "Location" "${::maint_prefix}/"
         return
      if { $uri starts_with "${::maint_prefix}/" } {
          trim off the maintenance prefix
         set uri [string range $uri $::maint_len end]
          Return the requested page
  log local0. "respond: [lindex $::maint_index_html 0]"
  switch $uri {
           "/index.html"   { HTTP::respond 200 content [lindex $::maint_index_html 0]           "Content-Type" "text/html" }
           "/logo.png"     { HTTP::respond 200 content [b64decode [lindex $::maint_logo_png 0]] "Content-Type" "image/png" }
           default         { HTTP::respond 404 }
  return
       If the all members in the default pool are down, redirect to the maintenance page
      if { [active_members [LB::server pool]] < 1 } {
        HTTP::redirect "${::maint_prefix}/index.html"
        return
Does anyone see whats going on? This is driving me nuts!!
Thanks,
Chris
Hi Chris,
I think one issue is that you’re using local variables in HTTP_REQUEST when setting the maint_prefix string (set maint_prefix “/maintenancepage”), but referencing a global variable (if {$uri equals ${::maint_prefix}}…) in the rest of the rule. Try changing the global variables to locals and see if you get better results. The Codeshare example declares the maint_prefix and maint_len variables in the RULE_INIT event. So they’re implicitly defined as globals, even though they don’t use the double colon in the name: ‘set ::global_var value’.
If you make that change and it still doesn’t work, can you log the output of [lindex $::maint_index_html 0]? Do you get the correct HTML string? If not, can you post what you see? Can you run ‘b class main_index_html list’ and post the output?
There are some other fixes/optimizations you could make to the example. You could save a few steps by using string map to trim off the maint_prefix. So instead of:
 set uri [HTTP::uri]
to:
 set uri [HTTP::uri]
 set uri [string map [list $maint_prefix ""] $uri]
Also, the redirect location should be an absolute URL (https://www.example.com/redirect_location.html) not just the path (/redirect_location.html):
ftp://ftp.rfc-editor.org/in-notes/rfc2616.txt
14.30 Location
The Location response-header field is used to redirect the recipient
to a location other than the Request-URI for completion of the
request or identification of a new resource. For 201 (Created)
responses, the Location is that of the new resource which was created
by the request. For 3xx responses, the location SHOULD indicate the
server’s preferred URI for automatic redirection to the resource. The
field value consists of a single absolute URI.
Location = “Location” “:” absoluteURI
An example is:
Aaron
Hi Aaron! Thanks again for the reply. You’ve always been extremely helpful.
I think I see a bit more with what is going on.
In the log output, I’m seeing:
can’t read “maint_index_html”: no such variable
I have it defined as class on the LTM, as a string and the file it is looking for is in /var/class. I have opened up the permissions just to make sure but no luck. I’m still not sure that I have made all of the variables global. Also, Where is the $::maint_index_html variable set, or becuase it is defined with the $:: it knows its a class?
What is your class name that contains the HTML? Is it named exactly maint_index_html? If so you can reference it using $::maint_index_html. Can you try this rule and see if it works for you?
      Test the maint_index_html class
     if {[info exists ::maint_index_html]}{
        log local0. "\[lindex \$::maint_index_html 0\]: [lindex $::maint_index_html 0]"
        log local0. "\$::maint_index_html doesn't exist!"
     set uri [HTTP::uri]
     if { $uri equals $maint_prefix } {
        HTTP::respond 301 "Location" "$maint_prefix/"
     } elseif { $uri starts_with "$maint_prefix/" } {
        switch $uri {
           "$maint_prefix/"             -
           "$maint_prefix/index.html"   {
           "$maint_prefix/logo.png" {
           default {
              HTTP::respond 404
        return
        HTTP::redirect "$maint_prefix/index.html"
If not, can you check the /var/log/ltm file for any errors or debug?
Thanks,
Aaron
Well! Closer…I added your updated code and now get the following in the LTM log:
TCL error: (rule name) - can’t read “maint_prefix”: no such variable while executing “string length $maint_prefix”
Here is a tested version which uses local variables. I changed the class names to end with _class so it’s a bit more clear that they’re not standard global variables. I also changed the logic so that only one test would be done if the request isn’t for a maintenance page. This should make the rule slightly more efficient for the majority of requests.
Can you update your class names to match these and give the rule below a try?
Thanks,
Aaron
Class containing the HTML:
class maint_index_html_class {
     type string
     filename "/var/class/maint.index.html.class"
Class containing the base64 encoded image:
class maint_index_logo_class {
     type string
     filename "/var/class/maint.logo.png.class"
iRule which references the HTML and logo class:
      log local0. "New request to: [HTTP::uri]"
      if { [HTTP::uri] starts_with "$maint_prefix" } {
          Strip off the $maint_prefix from the URI as you can't easily do variable expansion
          within a switch statement.
          Note that requests for the exact maintenance URI will be set to a null string,
          so handle null in the first switch case.
         set uri [string map [list $maint_prefix ""] [HTTP::uri]]
         switch -- $uri {
               log local0. "Request for $maint_prefix. Redirecting to $maint_prefix/"
            "/index.html" {
               log local0. "Request for index. Responding with content: [lindex $::maint_index_html_class 0]"
               HTTP::respond 200 content [lindex $::maint_index_html_class 0] "Content-Type" "text/html"
            "/logo.png" {
               log local0. "Request for logo.png. Responding with binary content"
               HTTP::respond 200 content [b64decode [lindex $::maint_logo_png_class 0]] "Content-Type" "image/png"
            default {
               log local0. "Unrecognized request to URI: [HTTP::uri]"
               HTTP::respond 404 content "Unrecognized request to [HTTP::uri]" "Content-Type" "text/html"
         return
Interesting!!
Why is it retuning the class file name to the browser instead of the contents of it!!
LTM logs shows:
Dec 5 08:54:11 tmm tmm[1709]: Rule fieldnet_oos : New request to: /maintenancepage/index.html
Dec 5 08:54:11 tmm tmm[1709]: Rule fieldnet_oos : Request for index. Responding with content: /var/class/maint.index.html.class
Browser “view source” contents:
What am I missing!?! Is there a version issue or something here?
Thanks again!!
I’d guess that your class isn’t defined correctly or the external file actually contains /var/class/maint.index.html.class. If you list the class definition you should see something like this:
b class maint_index_html_class list all
    type string
    mode rw
    partition Common
    "Maintenance pageSorry! This site is down for maintenance."
    none
    none
Can you post what you see?
Thanks,
Aaron
Hi All,
Any body can help me to create the i-rules via GUI, I have tried to create it by my self, but looks like the maintenance page is not working.
Have you checked out Kirk’s sorry page generator? Does all the work for you:
http://devcentral.f5.com/weblogs/jason/archive/2009/05/12/host-that-sorry-page-on-your-big-ip.aspx Click Here
Hi Nit,
Which LTM version are you running? What have you configured and what is not working?
Aaron
Hi All,
I have a new update, I successfully copy and create the irules, but my webpage show this:
Not the maintenance page that I created,
Please help..
Hi Aaron,
I’m using LTM BIG-IP 10.0.1 Build 378.0 Hotfix HF3, now I successfully created the irules but, the html page show only:
Hi Aaron,
I do b class list all
below is the result:
type string
timestamp 2010-11-23 09:36:52
filename “/var/class/maint.index.html.class”
mode rw
separator “:=”
partition Common
"Maintenance page
class maint_logo_png_class {
type string
timestamp 2010-11-23 15:23:48
filename “/var/class/maint.logo.png.class”
mode rw
separator “:=”
partition Common
"iVBORw0KGgoAAAANSUhEUgAAAL4AAAC3AgMAAADRFQzGAAAACVBMVEUAAADDAAD///8UoaPIAAElFTkSuQmCC"SLUHbWwzRlvrS1spJalnVcanB9Evvj8aLuZ3BX1Y1P+AUbgLzbWCp20NpfmAAAA
anything wrong in the class?
the irules as below:
Service requests for files (URIs) from the maintenance page.
Note that we always service these pages, even if the http_pool is up.
The maintenance prefix should be unique in the application and
not conflict with an existing directory on the web servers.
if { [HTTP::uri] starts_with “$maint_prefix” } {
Strip off the $maint_prefix from the URI as you can’t easily do variable expansion
Note that requests for the exact maintenance prefix URI will be set to a null string,
set uri [string map [list $maint_prefix “”] [HTTP::uri]]
Return the requested page based on the requested URI
switch -- $uri {
log local0. “Request for $maint_prefix. Redirecting to $maint_prefix/”
HTTP::redirect “$maint_prefix/index.html”
“/index.html” {
log local0. “Request for index. Responding with content: [lindex $::maint_index_html_class 0]”
HTTP::respond 200 content [lindex $::maint_index_html_class 0] “Content-Type” “text/html”
“/logo.png” {
log local0. “Request for logo.png. Responding with binary content”
HTTP::respond 200 content [b64decode [lindex $::maint_logo_png_class 0]] “Content-Type” “image/png”
default {
log local0. “Unrecognized request to URI: [HTTP::uri]”
HTTP::respond 404 content “Unrecognized request to [HTTP::uri]” “Content-Type” “text/html”
return
Hi Nit,
In 10.x, referencing the datagroup using $::datagroup_name will just return the datagroup name--not the contents. So you can change the [lindex $::datagroup_name 0] commands to:
[class element -value 0 datagroup_name]
Also, I’d suggest upgrading to 10.2.1 once it’s released as it contains a lot of fixes and enhancements over 10.0.1.
Aaron
Hi Aaron,
It’s still not working, now the web page is just empty and I have done the Maintenange Page Lite http://devcentral.f5.com/wiki/defau…eLite.html but looks like it will still send the maintenance page even if the pool_member is up (>1)
Any advice?
