ltm log entries when starting and stopping tcpdump
Every time I start and stop a tcpdump I get a notification for every tmm instance. Any advice to keep this out of the Ltm log file would be appreciated.
eg 8 times of the below for every start/stop notice tmm[13237]: 013e0001:5: Tcpdump starting bcast on 127.1.1.2:2 from 127.1.1.1:41796
Running 11.4.1
Look at the sys log-config “filter” clause here; myF5
Great, So I guess the extra information being put into the ltm log was introduced in one of the v11 releases, as I don’t recall seeing it, well especially for every tmm instance, in the ltm logs before.
For the record these are the commands I applied to remove it from the logs:
create filter start_stop_noise2 level notice message-id 013e0001
create filter start_stop_noise level notice message-id 013e0002
Obtaining each id via the ‘noise’ in the log Nov 30 10:20:22 hostname notice tmm7[13237]: 013e0001:5: Tcpdump starting bcast on 127.1.1.9:2 from 127.1.1.1:36013
I can see that information in v11.3.0, i guess its something I have’t noticed before. thanks for the reply.
