LTM is not responding, console is inaccessible
Hi, Actually I have a two boxes of big-ip ltm box (viprion c2400), suddenly the secondary box is not responding at all, even console is inaccessible, I did restart multiple times, it is not responding yet. so how do i troubleshoot it ?
have you tried to re-seat a blade or move it to another slot?
no, actually i removed it and returned it back to same slot, I will do change slot and let you know the result
I moved it to another slot, but still inaccessible.
you may have to contact support.
Hi, have this case solved in RMA support ticket or did you some workaround to that? Thank you.
