LTM - iRule operator
Hello,
We agree that I can simplify the line :
(not [HTTP::header “str1”] equals “str2”))
to
[HTTP::header “str1”] ne “str2”)
I have a doubt : Operators
Thank you.
LTM - 15.x
Hi cpt_ri_F5,
You can use “ne” operator for string comparisons. The function of the following two lines is the same.
not ([HTTP::header str1] equals "str2")
[HTTP::header str1] ne "str2"
eq ne: Boolean string equal and string not equal. Each operator produces a zero/one result. The operand types are interpreted only as strings
it is better to use gui based local traffic policy to avoid scripting typo
Hello, Thank you for your feedback,
@Enes_Afsin_Al , why did you remove the quotes from str1?
@zamroni777 , the iRule editor also validates the syntax.
Thank you
