LTM - irule : how can we set mirrot persistence in an irule
I am a real novice in F5. Until now we alway worked with ACE.
We should switch pool and sticky definitions depending on the HOST name:
when CLIENT_ACCEPTED { Save the name of the VS default pool set default_pool [LB::server pool] } when HTTP_REQUEST {
switch -exact "[string tolower [HTTP::host]]" {
    "acc-search.infrabel.be"           { pool /Common/a1185-acc-search.app/a1185-acc-search_pool
                                         persist none }
    "acc-mediaservice.infrabel.be"     { pool /Common/a1185-acc-mediaservice
                                         persist source_addr 255.255.255.255 180 }
    "acc-my.infrabel.be"               { pool /Common/a1185-acc-my
                                         persist none}
    "acc-officeweb.infrabel.be"        { pool /Common/a1185-acc-officeweb
    default                            { pool $default_pool }
We would not also set mirror persistence . The backup LB should take over sticky definitions whwhen needed.
How can we do this?
I can create a new (own) persistence profile with all in it. But how can we activate it in a our irule (using the GUY)
