I’m trying to configure a monitor that will check if a website is up on a Linux server. My Send string is GET /dms/loginForm.jpg HTTP/1.1\r\nHost:7270 \r\nConnection: close\r\n\r\n and if i leave the receive string blank it works and if I set the receive string to 200 OK it works, even though on of the sites is down. See below.
[Joseph.Johnson@US-MABILLDC-INTLTM-02:Active:Changes Pending] ~ curl -vk http://10.202.10.169:7270/dms/loginForm.jsp
- About to connect() to 10.202.10.169 port 7270 (0)
- Trying 10.202.10.169… connected
- Connected to 10.202.10.169 (10.202.10.169) port 7270 (0)
GET /dms/loginForm.jsp HTTP/1.1 User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1j zlib/1.2.3 libidn/0.6.5 Host: 10.202.10.169:7270 Accept: /
< HTTP/1.1 200 OK < Cache-Control: no-cache < Date: Thu, 10 Aug 2017 20:00:03 GMT < Pragma: no-cache < Content-Length: 2824 < Content-Type: text/html; charset=UTF-8 < Expires: Thu, 01 Jan 1970 00:00:00 GMT < X-ORACLE-DMS-ECID: dc812bacc6eaa1df:-521687cc:15dcd4a6325:-8000-0000000000000163 < Set-Cookie: JSESSIONID=zarNu3_3TyGdblWUPx-DjF7ACO-t3xgVoiK9zVVT3zGdcvNJXN1U!-1852036927; path=/; HttpOnly
[Joseph.Johnson@US-MABILLDC-INTLTM-02:Active:Changes Pending] ~ curl -vk http://10.202.10.70:7270/dms/loginForm.jsp * About to connect() to 10.202.10.70 port 7270 (0) * Trying 10.202.10.70… Connection refused * couldn’t connect to host * Closing connection 0 curl: (7) couldn’t connect to host
Why is it that even with no connection made, the monitor is still marking the pool member as up when i set the receive string to 200 OK and is there anything i should change with it?
Thanks in advance!
