LTM - HTTP monitor configuration
How to configure Http/Https monitor to look in to the content of a redirect string.
example - I am doing Http GET /app/id1 - On the webserver /app/idi is redirected to a different location.
From the F5 - if i use curl -L i am getting a correct response.
If anybody expereince this and having a solution please provide the HTTP monitor setting.
Regards,
Rajesh
Have you looked at the following
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/HTTPMonitor\_cURL\_BasicGET.html
CB
Thanks for the reply .
Could you please let me know what changes are required in the script to mark the node as down if i recieve the expected response (i.e Reverse option in the monitor)
Regards,
Rajesh
I believe in the script where it says “UP” you just use “DOWN”
Give that a shot
Hope this helps,
CB
It worked by changing the if statement
if[$? -ne 0] instead of if[$? -eq 0].
Thanks for your response..it helped
