LTM HA fail load ucs issue
Hello All :
This is LTM HA , load ucs 1 (Active) is ok , but load ucs 2 (standby) is error log .
please suggest with the steps to issue , how to fix the issue?
error log >> " failed. -- 01070712:3: /Common/dtdi.key Unexpected Error: Loading configuration process failed. "
thanks all
Per error it looks like you need to build device trust again. Are you testing setting in lab to real productions?​
yes , i only use one machine to test lab , so i need two machine tests lab ? , thank .:astonished_face:
If your planning to explore HA features and it’s behaviors, yes you need to setup a Lab HA pair.
If you need to run some tests scripts on the lab boxes, then a standalone itself is fine. No point of having a HA for lab unless you have real testing scenario. ​
