LTM DICOM Load Balancing
Hi all,
we have a new requirements to load balance DICOM server, which is medical images systems. those servers are listening on multiple ports so for now I have the VIP set up to listen on all ports until we get this sorted out.
to narrow the scope of troubling down, I have disabled one of the 2 pool members so that we would know what server we are connected to. I use a utility that tests the connectivity on port 104. if I connect to the pool member directly, it takes less than a second to complete, while if I test against the VIP itself, it takes about 45 seconds.
there’s nothing special about the VIP and all just about all defaults without http profile, because when I add the http profile, it goes to almost 2 minutes.
any ideas?
Hi Almassud,
We are getting the same results as you describe above. Could you please tell us if and how you solved above issue?
Looking forward to your answer
