LTM data-group limit
What would be the limit for string entries under LTM data-group? We have solution where we checking source ip and present different snat. For example
ltm data-group internal SNAT-USER {
records {
10.10.10.10 {
data SNAT-1
20.20.20.20 {
data SNAT-2
30.30.30.30 {
data SNAT-3
The reason I ask this question is we have around 50 data groups with 20-30 entries in each and I am looking to combine to 1. So wonder if there would be any limit to number of entries in single data-group.
Appreciate any help..
Data groups should be able to store about 100k entries, but if you’re going to start hitting these numbers you’d be better off considering an external data group.
That said, your looking at upto 1500 entries so you should be fairly safe
