LTM config issue
Hi, I am having an issue and would like your help on this. Below is my LTM network topology and it’s working, but I am having one NEW issue when creating a new network (10.4.0.0/24) for another set of web servers, the LTM is unable to ping those gateway 10.4.0.1 and web servers (10.4.0.0/24), but the LTM can ping other networks fine.
  1. created a new selfip 10.4.0.145 and floating ip 10.4.0.155
  2. assigned an ip 10.4.0.5 to the web server and gateway as 10.4.0.1.Verified the web server is working from my PC.
LTM can’t ping 10.4.0.1, so what am I missing here?
Outside network (192.168.0.0/24) selfip: 192.168.0.145 floatingip: 192.168.0.155
Internal network ( 10.2.0.0/24) selfip: 10.2.0.145 floatip: 10.2.0.155
management network: (10.1.0.0/24) selfip: 10.1.0.145
HA network: (10.3.0.0/24) selfip: 10.3.0.145 floatip: 10.3.0.155
web servers ips: web1: 10.2.0.16 web02: 10.2.0.27 web3: 10.2.0.18
Is the LTM connected to the same LAN segment as the servers on 10.4.0.0/24 ?
Also, this may seem trivial, but windows servers tend to not respond to ping by default, so make sure that this is not your problem (you can test http connection instead)
Hi The LTM is connected to the same LAN segment 10.4.0.0/24, the same way I setup for 10.2.0.0/24 ( this one is working for ping, ltm config, access, etc, happy). I ignored the ping issue on the LTM for now, but when I tried to add a new node using 10.4.0.0/24, LTM monitoring failed, right away I know something was not right. If you look at configs that I posted earlier, I added 10.4.0.0/24 on the internal interface, but that did not do any good. Any thoughts?
back up a little. What vlan is “internal”? Is it tagged? What vlan is 10.4.0.0/24 supposed to be on? Have you assigned the self-IPs to the correct vlan? It’s difficult to guess what’s going on, except to suspect that you may have added the IP to the wrong vlan (if they are directly connected to the same lan segment), or if they are not directly connected, then you don’t have a route configured or the router is not configured to forward the packets it’s getting.
Could you please check the interfaces on the F5 check the truck and VLANs ? May be something wrong there
Regards,
Hi, this is what I have is working right now meaning I can create VIP and it’s accessible. All interfaces are configured untagged. 1. Internal Vlan (10.2.0.0/24) → selfIP .145/floating .155 2. External Vlan (192.168.50.0/24) --> selfip .145/floating .155 3. HA Vlan (10.3.0.0/24)--> selfip--> 10.3.0.145/floating .155 4. Management (10.1.0.0/24) -->selfip-->10.1.0.145 5. Gateway--> 192.168.50.1 Now I am having a new network 10.4.0.0/24, GW 10.4.0.1, assigned .11/.12 to two web servers. The steps I configured in LTM and it’s not working. How would you add config a new network in LTM? add a new config: 1. Vlan->new selfip--> 10. 4.0.145, float-->10.4.0.155 on internal VLan
just want to make a note from my last post is that 10.4.0.1 is a gateway that being configured only for the web servers NOT on the LTM.
