Hello, I am trying to change the DEFAULT cipher used in a SSL Profile (client) with the following cipher string “!LOW:!SSLv3:!MD5:!RC4-SHA:!EXPORT:ECDHE+AES-GCM:ECDHE+AES:AES-GCM+RSA:RSA+AES” but I get the error “01070312:3: Invalid keyword ‘aes-gcm’ in ciphers list for profile /Common/wildcard.esignal.com”
What is the correct usage of the cipher string above? I am using it on an LTM ver 11.4.1 Thanks.
