Hi, - in regards to auction.f5demo.com ( hack it yourself website practice labs )
I’m attempting to configure an ASM lab according to link text
Instructions ASSUME that the LTM is already set up and nothing further is given in that regard. I tried just about everything, configure Vlans, self-ip’s, VS, Pool. but still no joy. Has anyone got base config for LTM based on the URL I just posted please. I just feel I’m wasting so much time needlessly. I just want to get on with ASM practice labs.
OK, you need an internal VLAN for interface 1.2
Create a self-IP in the 10.128.20.0/24 subnet on the internal vlan.
You should be able to ping 10.128.20.150 (the phpAuction vm)
create the auction_pool pool
the monitor should go green
Create an external VLAN for interface 1.2 Create a self-IP in the 10.128.10.0/24 subnet on the external vlan.
Then create the virtual server 10.128.10.35 on the external VLAN
You should be able to ping this address, and connect to the phpAuction site.
C’mon man, why you looking at asm if you are not able to set up basic ltm?
All you need for this is the vmnets to be in order, then vlans, selfips etc.
You can download the vlabs from and get the ltm setup from there and start from there.
