LTM and GTM objects modification
I am working on migrating existing VIPs into new Route Domain I created, I need help with the following (without editing the config file and reloading it): I am running 11.4.1 HFX10
1- LTM pool members: I need to add %5 to each member without effecting the health monitor of the member specific nodes.
*Ex: modify ltm pool mysite_443_pool members add {10.10.10.10%5:5050}
(using this cause me to lose the member specific health monitor and it will inherit from the pool).*
2- LTM VS: I want to replace the existing VIP and VLAN for each VS.
Ex: modify ltm virtual mysite_443_vs source 0.0.0.0%5/0 destination 10.10.10.11%5:443 vlans-enabled snat automap (using this doesn’t let me chose a VLAN from the available list)
3- GTM pool members: Assign the new VIPs to the existing wide-IPs.
(I have multiple servers on the GTM data centers, the list of VS shows as /Common/mysite_VS_443) how can I assign it to a wide-IP?
Any help is highly appreciated. Thank you.
  1. Just guessing - may be the member specific monitor has a specific IP address ? If not, can you provide the configuration ?
  2. Some VLANs are showing up and others aren’t ? What if you remove snat automap, can you see all the VLANs ?
