LTM 1600 does not boot, stuck on "Press <esc>( for Command Menu...</esc>
After power on LTM 1600 the booting process stops at
--- Press ( for Command Menu, or for Host console.
: “C102”
When I hit Enter, nothing happens Sometimes ( works and I can see AOM Command Menu and I can setup AOM network and then SSH.
Why this system does not boot? What is the next step to figure out what is wrong?
Thank you
You are stuck in SCCP mode. Please follow this article myF5 to reset sub host system before access TMOS.
