LTM 12 Radius load balancing datagram lb
I set up a virtual server to balance radius authentications using a custom Irule to have calling station Id as persistence attribute by uie. I kept datagram lb disabled as suggested by all deployment guides when clients use mschapv2. Nothing worked as long I kept datagram lb disabled, as soon as I enabled it maschapv2 authentication began to work. Unfortunately all the guides I read refer to bigip version 11. Is there something new in version 12? Please note that on our environment there is not source Nat of the clients. Thanks Marco
There is nothing new in relation to the datagram LB option.
As you can see in this solution, is the same since version 9.0.3:
