LTM 11.1.0+ HTTP monitor with native NTLM auth
After struggling for a few hours with HTTP monitors using the native NTLM solution (after the initial BASIC auth request fails), I’m not convinced that it’s correctly forming the NTLM request.
The web server constantly returns 401.2 responses and the following is logged in to the server’s Security event log:
Account For Which Logon Failed:
Security ID: NULL SID
Account Name:
Account Domain:
Failure Information:
Failure Reason: Unknown user name or bad password.
Status: 0xc000006d
Sub Status: 0xc000006a
It seems that 0xc000006a means “User logon with Misspelled or bad Password”. I know for a fact that the password specified in the monitor is correct, and when capturing the BASIC auth request it shows as such; something is going wrong during the NTLM auth request.
Since the request is hashed I’ve got no way of figuring out whether the username and password are correct so I was wondering if anyone else has successfully used the native NTLM auth functionality of the HTTP monitor since it was implemented in 11.1.0.
Hi David,
Can you open a support case on this. If I get a chance, I’ll try testing here as well.
Aaron
would you mind posting the http monitor configuration?
tmsh list ltm monitor (monitor name)
and can you post http monitor response? it is http (not https), isn’t it?
ssldump -Aed -nni (vlan name) host (selfip) and host (pool member ip) and port (pool member port)
Here’s the monitor, I’ll dump the HTTP response in a bit …
ltm monitor http QA_ShortURL_Monitor {
defaults-from /Common/http
destination *:*
interval 30
partition WebSystems
password “****”
recv “StatusCode: 200, Ok”
send “GET / HTTP/1.1\\r\\nHost: qa-shorturl-2008-f5”
time-until-up 0
timeout 61
username DOMAIN\\svc_f5HTTPMonitor
I had to remove the trailing \r\n as it was causing malformed headers in the HTTP request which it appears is a known bug when using NTLM auth on a monitor.
this is mine.
root@v1110(Active)(/Common)(tmos) show sys version
Sys::Version
Main Package
  Product  BIG-IP
  Version  11.1.0
  Build    1943.0
  Edition  Final
  Date     Sun Nov 20 18:27:50 PST 2011
root@v1110(Active)(/Common)(tmos) list ltm monitor http myntlm
ltm monitor http myntlm {
    defaults-from http
    destination *:*
    interval 5
    password secret
    recv "200 OK"
    send "GET /index.html HTTP/1.1\\r\\nHost: 172.28.19.78"
    time-until-up 0
    timeout 16
    username tasmania@abc.com
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.02 20:43:47 =~=~=~=~=~=~=~=~=~=~=~=
[root@v1110:Active] config
[root@v1110:Active] config  ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.20.11(41539) <-> 172.28.19.78(80)
1349181834.6342 (0.0024)  C>S
Host: 172.28.19.78
Authorization: Basic dGFzbWFuaWFAYWJjLmNvbTpzZWNyZXQ=
1349181834.6351 (0.0009)  S>C
HTTP/1.1 401 Unauthorized
Content-Length: 1656
Content-Type: text/html
Server: Microsoft-IIS/6.0
WWW-Authenticate: Negotiate
WWW-Authenticate: NTLM
Date: Tue, 02 Oct 2012 12:40:33 GMT
...snipped...
1349181834.6360 (0.0009)  C>S
Host: 172.28.19.78
Authorization: NTLM TlRMTVNTUAABAAAAB4IIAAAAAAAAAAAAAAAAAAAAAAA=
1349181834.6370 (0.0009)  S>C
Content-Length: 1539
WWW-Authenticate: NTLM TlRMTVNTUAACAAAABgAGADgAAAAFgokCqL4wD9Ebc7wAAAAAAAAAAGIAYgA+AAAABQLODgAAAA9BAEIAQwACAAYAQQBCAEMAAQAMAFMAQQBMAE0ATwBOAAQADgBhAGIAYwAuAGMAbwBtAAMAHABzAGEAbABtAG8AbgAuAGEAYgBjAC4AYwBvAG0ABQAOAGEAYgBjAC4AYwBvAG0AAAAAAA==
...snipped...
1349181834.6382 (0.0011)  C>S
Host: 172.28.19.78
Authorization: NTLM TlRMTVNTUAADAAAAGAAYAGgAAACSAJIAgAAAAAAAAABAAAAAIAAgAEAAAAAIAAgAYAAAAAAAAAASAQAABYKIonQAYQBzAG0AYQBuAGkAYQBAAGEAYgBjAC4AYwBvAG0AYgBpAGcAZAAzDBf+CcqPFXMNzakQDxm1eyzebeEbgH6jUUWxR+l6hbBzQbvr5UqfAQEAAAAAAAAAIcaUm6DNAXss3m3hG4B+AAAAAAIABgBBAEIAQwABAAwAUwBBAEwATQBPAE4ABAAOAGEAYgBjAC4AYwBvAG0AAwAcAHMAYQBsAG0AbwBuAC4AYQBiAGMALgBjAG8AbQAFAA4AYQBiAGMALgBjAG8AbQAAAAAAAAAAAA==
1349181834.6400 (0.0018)  S>C
HTTP/1.1 200 OK
Content-Length: 12
Last-Modified: Tue, 02 Oct 2012 11:29:51 GMT
Accept-Ranges: bytes
ETag: "c81b63d91a0cd1:251"
hello world!---------------------------------------------------------------
1    1349181834.6413 (0.0012)  C>S  TCP FIN
1    1349181834.6420 (0.0007)  S>C  TCP FIN
