LTM 11.1.0 Cookie httponly flag TCL errors
All,
Have deploy cookie httponly flag for PCI compliance. New irule takes down the website when applied. I am running http classes and i had to do httpclass disable for other irules. Has anyone run into this issue?
Thanks,
Bryce
when HTTP_RESPONSE {
Check if the response contains the persistence cookie
if {[HTTP::cookie BIGipServerWeblogic_Pool_STAGING] ne “”}{
Set the httponly flag on the persistence cookie if it is in the response
HTTP::cookie httponly BIGipServerWeblogic_Pool_STAGING enable
TCL Errors
Jun 19 18:07:14 tmm2 err tmm2[8165]: 01220001:3: TCL error: /Common/BBB_Staging_Cookie_Flag - Improper version (line 7) invoked from within “HTTP::cookie httponly BIGipServerWeblogic_Pool_STAGING enable”
Jun 19 18:07:14 tmm err tmm[8163]: 01220001:3: TCL error: /Common/BBB_Staging_Cookie_Flag - Improper version (line 1) invoked from within “HTTP::cookie httponly BIGipServerWeblogic_Pool_STAGING enable”
Jun 19 18:07:17 tmm2 err tmm2[8165]: 01220001:3: TCL error: /Common/BBB_Staging_Cookie_Flag - Improper version (line 5) invoked from within “HTTP::cookie httponly BIGipServerWeblogic_Pool_STAGING enable”
Jun 19 18:07:29 tmm3 err tmm3[8166]: 01220001:3: TCL error: /Common/BBB_Staging_Cookie_Flag - Improper version (line 7) invoked from within “HTTP::cookie httponly BIGipServerWeblogic_Pool_STAGING enable”
Hey Bryce,
Sorry for the slow reply on this. I got sidetracked. Because HttpOnly can only be set for cookies with version 1 or 2 and the default version is 0, this is probably the cause of the problem. Can you set the version to 1 first:
Set HttpOnly on all LTM and app generated cookies
   set cookieNames [HTTP::cookie names]
   foreach aCookie $cookieNames {
      HTTP::cookie version $aCookie 1
      HTTP::cookie httponly $aCookie enable
 Or just for one statically defined cookie:
   HTTP::cookie version myCookie 1
   HTTP::cookie httponly myCookie enable
Aaron
i got illegal argument error on HTTP::cookie version.
Jun 21 14:27:01 ve11a err tmm1[10969]: 01220001:3: TCL error: /Common/myrule  - Illegal argument (line 1)     invoked from within "HTTP::cookie version BIGipServerfoo 1"
so, i remove cookie and add it back later.
e.g.
[root@ve11a:Active:Changes Pending] config  tmsh list ltm virtual bar
ltm virtual bar {
    destination 172.28.20.16:80
    ip-protocol tcp
    mask 255.255.255.255
    persist {
        cookie {
            default yes
    pool foo
    profiles {
        http { }
        tcp { }
    rules {
        myrule
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vlans-disabled
[root@ve11a:Active:Changes Pending] config  tmsh list ltm rule myrule
ltm rule myrule {
  if { [HTTP::cookie BIGipServerfoo] ne "" } {
    set ck_value [HTTP::cookie value BIGipServerfoo]
    set ck_path [HTTP::cookie path BIGipServerfoo]
    HTTP::cookie remove BIGipServerfoo
    HTTP::cookie insert name BIGipServerfoo value $ck_value path $ck_path version 1
    HTTP::cookie httponly BIGipServerfoo enable
[root@ve11a:Active:Changes Pending] config  curl -I http://172.28.20.16
HTTP/1.1 200 OK
Date: Fri, 21 Jun 2013 06:58:06 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Thu, 23 May 2013 00:28:46 GMT
ETag: "4185a8-59-c3efab80"
Accept-Ranges: bytes
Content-Length: 89
Connection: close
Content-Type: text/html; charset=UTF-8
Set-Cookie: BIGipServerfoo=1707657416.20480.0000;HttpOnly;Path=/;Version=1;
Aaron,
Thanks for you quick response. I just need the httponly flag for 2 cookies. Going to perform the following iRule on staging.
Thanks,
Bryce
Check if the response contains the Foo cookie
if {[HTTP::cookie BIGipServerWeblogic_Foo] ne “”}{
HTTP::cookie version BIGipServerWeblogic_Foo 1
HTTP::cookie httponly BIGipServerWeblogic_Foo enable }
Check if the response contains the FooBoo cookie
if {[HTTP::cookie FooBoo] ne “”}{
HTTP::cookie version FooBoo 1
HTTP::cookie httponly FooBoo enable }
I get the same error - illegal argument error on HTTP::cookie version. Any solution?
have you read the replies above, one solution would be to set the version. did that work for you?
