Am trying to set values for syslog config. I can get get/set_value methods to work but would like to set multiple values and am having trouble with get/set_values. Tried several different things but am not getting any values returned for get_values. Am missing something stupid.
In [297]: b.LTConfig.Field.get_value.params
Out[297]:
[(class_instance_key, u’LTConfig.ClassInstanceKey’),
(field_instance_name, u’string’)]
In [298]: syslog_instance = b.LTConfig.Class.typefactory.create(‘LTConfig.ClassInstanceKey’)
In [299]: syslog_instance
Out[299]:
(LTConfig.ClassInstanceKey){
container = None
container_class = None
class_name = None
name = None
In [300]: syslog_instance.class_name = “syslog”
In [301]: syslog_instance.name = “syslog”
In [302]: b.LTConfig.Field.get_value(class_instance_key = syslog_instance, field_instance_name = ‘include’)
Out[302]: destination loghost { udp(10.20.5.11 port (514)); udp(10.20.4.167 port (514)); };
In [303]:
In [303]: b.LTConfig.Field.get_values.params
Out[303]:
[(class_instance_keys, u’LTConfig.ClassInstanceKeySequence’),
(field_instance_names, u’Common.StringSequenceSequence’)]
In [304]: class_instance_key_seq = b.LTConfig.Class.typefactory.create(‘LTConfig.ClassInstanceKeySequence’)
In [305]: class_instance_key_seq
Out[305]:
(LTConfig.ClassInstanceKeySequence){
_arrayType = “”
_offset = “”
_id = “”
_href=“”
_arrayType = “”
In [306]: class_instance_key_seq.item = [ syslog_instance ]
In [307]: class_instance_key_seq
Out[307]:
_arrayType = “”
_offset = “”
_id = “”
_href=“”
item[] =
container = None
name = “syslog”
In [308]: field_instance_names_seq = b.LTConfig.Class.typefactory.create(‘Common.StringSequenceSequence’)
In [309]: field_instance_names_seq
Out[309]:
(Common.StringSequenceSequence){
_arrayType = “”
_offset = “”
_id = “”
_href=“”
_arrayType = “”
In [310]: field_instance_names_seq.item = [ ‘include’ ]
In [311]: field_instance_names_seq
Out[311]:
_arrayType = “”
_offset = “”
_id = “”
_href=“”
item[] =
“include”,
In [312]: b.LTConfig.Field.get_values(class_instance_keys = class_instance_key_seq, field_instance_names = field_instance_names_seq )
Out[312]: [[]]
Note: I don’t get an error but don’t get any return values. Much less when trying to get multiple fields,
ex.
field_instance_names_seq.item = [ ‘include’, ‘authpriv_from’ ]
Tried various other structures like
get_values(class_instance_keys = [ syslog_instance ] , field_instance_names = [[‘include’]] )
to no avail.
Also Note, there is not an exact one-to-one mapping between output of get_list and tmsh fields (ex. in syntax = authpriv_from vs. auth-priv-from as well as no “remote-servers” field in iControl) Not quite sure why that is ???
ex.
In [325]: b.LTConfig.Field.get_list(class_names = [‘syslog’])
Out[325]: [[authpriv_from, authpriv_to, console_log, cron_from, cron_to, daemon_from, daemon_to, description, include, iso_date, kern_from, kern_to, local6_from, local6_to, mail_from, mail_to, messages_from, messages_to, userlog_from, userlog_to]] In [326]:
vs. tmsh
[root@demo:Active] config tmsh list sys syslog all-properties
sys syslog {
auth-priv-from emerg auth-priv-to emerg cron-from warning cron-to emerg daemon-from notice daemon-to emerg include “destination loghost { udp(10.20.5.11 port (514)); udp(10.20.4.167 port (514)); };” kern-from notice kern-to emerg mail-from notice mail-to emerg messages-from notice messages-to warning remote-servers none user-log-from notice user-log-to emerg
