Any time we restart the F5 we must manually re-add the static route. Do this sound right? Shouldn’t routing persist? Thanks.
The issue appears when restarting the Standby. We would think that the configuration settings such as static routes save over to the Standby but perhaps some configuration settings do not.
Jon,
Each time you reboot it doesn’t save said static route which is on the active. According to that it looks like whenever you do the initial sync for the HA pair I am curious if it even gets carried over in the first place (since I am assuming a fail-over has not occurred.)
Whenever syncing the device I would sync the active to the group, and ensure “overwrite configuration” is enabled as well.
Thanks you Nicholas. Let me check on that with my administrators on the steps they normally take.
