Here is my scenario
SIP VoIP
A(1.1.1.1) SUBSCRIBE --> F5 VS(2.2.2.2) --> B(3.3.3.3)
A <-- F5 VS <-- 200OK B
A <-- F5 VS <-- NOTIFY B
My issue is on the NOTIFY. When F5 sends to A it still has F5 IP address in URI. How would I lookup the A IP address in the persist table so that I can use the irule to replace the uri?
Everything works fine in regards to persistence and flow.
So instead of uri looking like
NOTIFY sip:2.2.2.2
I need it to be
NOTIFY sip:1.1.1.1
Is there another way to store the IP address?
Tx
Darren
yahoo-darren_voip
Hey Darren,
I will disclaim this by stating that my experience with the SIP profile on the LTMs is fairly limited, so I could be missing something critical in my analysis. I believe, though, you can use the IP::remote_addr to get the appropriate address. ( http://devcentral.f5.com/wiki/default.aspx/iRules/IP\_\_remote\_addr.html ) You might need to use the clientside/serverside commands ( http://devcentral.f5.com/wiki/default.aspx/iRules/clientside.html ) to be sure that this grabs the correct address, though.
I believe the sample in the SIP::uri page attempts to accomplish something similar, actually: http://devcentral.f5.com/wiki/default.aspx/iRules/SIP\_\_uri.html It seems like it would probably be wise to check the current SIP::uri to see if it mathes IP::local_addr and, if so, replace it with IP::remote_addr.
Again, my SIP-fu is weak, so feel free to correct me if I have a fundamental misunderstanding of the protocol. (Which is likely.)
// Ben
