I would like to implement per-message (instead of per session) load balance to backend servers in long live HTTPS session. Is it possible to do that?
If the app doesn’t require session persistence, you could disable persistence and add a OneConnect profile to the VIP.
Aaron
Here is some information about OneConnect
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=114
http://devcentral.f5.com/Wiki/default.aspx/AdvDesignConfig/OneConnect.html
404 Page not found | BIG-IP Documentation (Requires ask.f5.com login)
I hope this helps
Thanks,
Bhattman
