Logon Load balancing in SAP can it be delivered by F5
Is it possible for F5 to deliver capability similar or better than Logon Load balancing in SAP and if so would it be a advantage in terms of user experience or server load.
The application attributes specially Variable CPIC_MAX_CONV is configured with min 200 and max as per the hardware sizing and capability. It is possible for F5 to dynamically align to the server environment assuming that the server farm is not equal configuration.
Can you share the documents from F5 and SAP if the above can be achieved. Thank you for the assistance.
Hi MD. Is the context of your question SAPGUI or are you using NetWeaver HTTP?
Thanks for the context MD. There is no co-developed F5-SAP solution for what you describe, but it would definitely be an interesting project.
