Logon Denied with IE7 upgrade
Can anyone lend a helping hand.
I have a few users who recently upgraded to IE7 and now they are recieving a Logon Denied error “Your device does not comply to current client security policies”
Are there any modifications I need to make on the Firepass to allow users to logon using IE7?
The screen shot is attached.
Please advise.
-Marine
Marine, what version of FirePass are you running? Do you have any information regarding the FirePass’s client security requirements for your users?
At this point, I do not know. Where might I find this information.
Your device does not comply to current client security policies. message is coming from the anitivirus scan F5 is running. I recently was connecting with Windows 7 and firefox and running MS Essentials for Anitivirus. My company applied the latest update of F5 that would allow new antivirus products to connect and now My Windows 7 doees not connect regardless of what anitivirus I’m running. So I am at a lost as well.
Posted By sandra bermudez finn on 12/05/2009 9:53 AM
Just a question but don’t you talk to your IT folks? I mean they can tell you what the issue is if you explain to them the situation.
Microsoft Security Essentials was not supported on 12/5, in addition they can be running registry checks, os checks etc… to determine if your device is compliant.
