I’m working with the technical guys at a client and a question from one of the engineers comes up. Something like “Since we didn’t buy the 5250V, how’re we going to be able to isolate the internal and external environments?”
How would you respond to this question?
Partitions would seemingly help. Does anyone have experiences with this approach (good or bad) to share?
The real question I should have been asking is: “Do route domains make administrative partitions more secure in some way?” The answer seems to be no so we’ll be moving forward with administrative partitions without the added complexity of route domains.
Are you talking about the configuration on the F5 or network traffic? If you are talking about configuration of the F5; virtual servers, pools, monitors, iRules, ect., then partitions will provide a security separations.
If you are talking about network traffic flows. Then using separate physical interfaces along with route domains will keep the traffic separated.
