Hi Team,
Currently as per the below logic we are having an Irule named: “irule_blocks” containing the below:
when HTTP_REQUEST priority 500 { if {[class match [HTTP::uri] contains dg_glob_block_contains]}{ HTTP::redirect “http://www.xyz.com” } elseif {[class match [HTTP::uri] starts_with dg_glob_blocks_starts_with] || [class match [HTTP::uri] starts_with dg_l_mgd_url_blocks] } { HTTP::respond 302 Location “http://www.xyz.com” } }
So, as per the existing logic we have : 1) 301 ( permanent) redirects file is “dg_glob_block_contains"
2) 302 redirects against Data-Group:“dg_glob_blocks_starts_with” and “dg_lenovo_mgd_url_blocks”
Now as per the new Logic we have to do the below: 1) We need “dg_glob_block_contains” & “dg_glob_blocks_starts_with” should be permanent (301 redirect).
2) while “dg_l_mgd_url_blocks” should be in 302 redirect.
So, how my existing Script/Irule will look like as per the new required logic.
Thanks and Regards Pz
