Logging payload length and part of message
Hello
I am looking into logging a TCP request and response through an iRule. I am happy with performing the logging in an iRule as I have done this before but this is the first time I have tried to capture payload. First of all I want to look at collecting the message length of both the request from the client and the response from the server. Secondly I would like to capture a reference from the a certain position within the message. This is always in the same position of the message as that part is fixed length. The actual message contains a two byte header that logs the message size calculated by the application an example is: 0x00 0x09 STX Message ETX What would be useful is to log the actual message length received by both the client and server secondly logging the length in the request from the client and response from the server. The message reference mentioned above only needs to be collected from the request message from the client and does not need to be captured from a server response.
Any help would be appreciated.
Given that you want to see client request and server response sizes, you could do something like this:
when CLIENT_ACCEPTED {
    TCP::collect
when CLIENT_DATA {
    set cs_len [TCP::payload length]
    set cs_payl [TCP::payload]
    TCP::release
when SERVER_CONNECTED {
    TCP::collect
when SERVER_DATA {
    set ss_len [TCP::payload length]
    set ss_payl [TCP::payload]
    log local0. "Client side ($cs_len) = $cs_payl, Server side ($ss_len) = $ss_payl"
    TCP::release
This is logging the entire request and response payloads, so you’d need to customize as required.
