Hello,
I want to output rejections for this iRule to a syslog server. My syntax is
when HTTP_REQUEST { if { !(([HTTP::host] starts_with “website.co.uk”) or ([HTTP::host] starts_with "
or ([HTTP::host] starts_with “backup.mywebsite.co.uk”) or ([HTTP::host] starts_with ";)) } { discard } {log local0. “blocked [HTTP::header “User-Agent”] requesting [HTTP::host][HTTP::uri]”} }
I tried the following as well;
or ([HTTP::host] starts_with “backup.mywebsite.co.uk”) or ([HTTP::host] starts_with ";)) } { discard } log local0. “blocked [HTTP::header “User-Agent”] requesting [HTTP::host][HTTP::uri]” }
Which DID log but didn’t show correctly in syslog.
Basically I want the syslog message to use the keyword ‘blocked’ to make searching easier.
Hi, What about doing this way?
switch -glob [string tolower [HTTP::host]] {
"website.co.uk*" -
"www.website.co.uk*" -
"backup.mywebsite.co.uk*" -
"www.backup.mywebsite.co.uk*" {
nothing to do
default {
log local0. "blocked [HTTP::header "User-Agent"] requesting [HTTP::host][HTTP::uri]"
discard
It works for you? I hope so.
Regards.
Do you really mean
starts_with
in these cases? Since .uk is a top-level domain, I assume you are not expecting Host header entries for something like “website.co.uk.foo.bar.baz.com”. I ask because dropping the glob matching (and the asterisks at the end of the hostnames) makes the rule a bit faster, and I presume, more correct.
Also,
log
delivers to the local syslog facility on the BIG-IP, which (unless you changed the syslog.conf) means it is going to a local file on the BIG-IP. If you want remote syslog, the best avenue is to use High Speed Logging from within your iRule:
Do you really mean
starts_with
Also,
log
Have you tried, the below, where User-Agent is without quotes and has value?
if { !(([HTTP::host] starts_with "website.co.uk") or ([HTTP::host] starts_with "www.website.co.uk";) or ([HTTP::host] starts_with "backup.mywebsite.co.uk") or ([HTTP::host] starts_with "www.backup.mywebsite.co.uk";)) } {
log local0. "blocked [HTTP::header value User-Agent] requesting [HTTP::host][HTTP::uri]"
discard
For sure that for non-standard port, the “starts_with” is relevant to him.
So, the “log” command out of “if” statement, will register log even that is not blocked, am I wrong?
Respectfully.
Was a copy paste from the rule above, but yes, that is correct. I moved it up in though.
Thanks for your help guys
