We have 2 LTM 9.4 and would like to log all loadbalanced connections going thru the F5 (mostly IP info). I have an external syslog setup monitoring (warning…emerg) what level should i set to see these connnections occuring? And is there a way to just filter on these connections?
To log all client connections through the BIG-IP, you can use an iRule and modify the syslog-ng configuration. You could trim down this rule to just log the client and server IP’s (Click here)
Within the log statement, you can specify the syslog facility and severity:
log facility.severity “log text”
example:
log local0.info “some text”
There are examples of how to configure syslog-ng to log to a remote syslog server as well (Click here).
Thx Hoolio! I tried applying this TCP/HTTP irule to our external VIP. Will this still work if our VIP is only available for HTTPS? Or do I need to create a separate HTTPS policy?
If you’re decrypting the HTTPS on the BIG-IP using a client SSL profile, you can use the HTTP logging rule. If you’re not decrypting the HTTPS, then you can’t inspect the HTTP headers or data--you could log IP, port and SSL info (cipher levels, etc), but not HTTP.
