I am sending my BigIP logs to a remote splunk server. I am trying to find the HA failover code to generate a report to notify us on failover. I have the logs working but when I perform a failover I am not seeing anything being generated in splunk. Any ideas?
standy/active status logs already to /var/log/ltm, so if you are shipping your logs that message should be present. That said, you can also configure /etc/alertd/alert.conf to snmptrap or email from these events:
alert BIGIP_SOD_SODERR_SOD_STANDBY {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.14";
lcdwarn description="Unit going standby." priority="5"
alert BIGIP_SOD_SODERR_SOD_ACTIVE {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.15";
lcdwarn description="Unit going Active." priority="5"
Details are in Solution 3727
I believe it’s the ltm log, do you see an entry in here when you fail over? If not then check your logging levels in the GUI (although I would guess the default level would catch this). Hope this helps, N.
