Log Tcp And Http Request Response Info Remotely -- not working
Hi All,
I used this iRule https://devcentral.f5.com/wiki/iRul…otely.ashx
But unable to get it working, no request are being logged. Other message from BigIP are logged.
Can someone tell me what else do I need to do.
syslog_server_pool is create with 1 member and it shows up.
//Mairo
tried with log remote, even this is not working.
Hi Mario,
Is the pool reachable via a TMM switch port (ie, not the mgmt port)? Do you see any packets being sent to the server? You can use tcpdump like this to check (where 1.1.1.1 is the syslog server):
tcpdump -enni 0.0 -Xs0 host 1.1.1.1
Aaron
Oh, the pool is only reachable via mgmt port. Is that the reason?
Thanks Aaron.
Working via TMM switch port. Any idea how to get it working via mgmt port?
If you are looking for a way to sniff the management port:
tcpdump -enni eth0 -Xs0 host 1.1.1.1
The pool members should not be reachable via management port.
