I’m trying to use the log statement to help me debug whether I’m passing through pieces of a rule. But I must be missing something, because nothing ever shows up in /var/log/bigip. Here’s a simple test rule:
if (http_uri == “/”) {
redirect to “https://%h/Epm1”
log “redirected blank URI”
else {
use pool main-qa-8080
Pretty simple. The rule is the resource of a virtual server which is the destination host of an ssl proxy. And the rule is working - that is, I can go to the URL which resolves to the ssl proxy: https://main-qa.blueroads.com and I successfully get redirected to https://main-qa.blueroads.com/Epm1. So clearly I’m passing through the if part of the rule. However, nothing ever shows up in /var/log/bigip.
Just to be sure it should be going to /var/log/bipip, I modified the rule to read:
log level0.info “redirected blank URI”
else {
since level0.* is associated with /var/log/bigip in /etc/syslogd.conf.
What am I missing? Why am I not seeing entries in /var/log/bigip with my “redirected blank URI” message?
Cheers,
Steve
