I need to know how to configure log rotation on a BigIP ASM module witch log locally
Hello, hope this link will help you 404 Page not found | BIG-IP Documentation
Hello Vitaly, Yes of course!! Last question: Witch is the default setting for log rotate (OS 11.6) ? When I configure ASM to log locally, logs are written on local DB correct? Witch is the capacity of that DB and what happen when DB is full?
Thank you very much!
You can check your system settings:
(tmos) list sys db logrotate.logage
Log stores in files /var/log/asm, the capacity for log storing is the size of /var/log partition
perfect Thank you!
