localLBPersistenceMode constructor
I am not able to create a LocalLBPersistenceMode class. The constructor requires a String as argument, however it complains that the constructor LocalLBPersistenceMode(String) is not visible.
Has anyone out there created a LocalLBProfilePersistence sucessfully using iControl.Assembler for java 11.1.1?
Any idea?
Thanks, Mike Tan
-------------------section of the code ---------------------------------
String [] localLBProfilePersistence = new String[1];
iControl.LocalLBPersistenceMode[] localLBPersistenceMode = new iControl.LocalLBPersistenceMode[1];
localLBPersistenceMode[0]= new LocalLBPersistenceMode(iControl.LocalLBPersistenceMode._PERSISTENCE_MODE_UIE);
//localLBPersistenceMode[0]= new LocalLBPersistenceMode();
i_interfaces.getLocalLBProfilePersistence().create(localLBProfilePersistence, localLBPersistenceMode);
the LocalLB.PersistenceMode type is an enumeration. If it were a structure, you would have to allocated a new one for each array element, but you don’t for an enum. Think of it just like a native type (int, long, etc). You just have to allocate the correct array size and then assign it a value, just like you would for a “long []” type.
Something like this:
iControl.LocalLBPersistenceMode[] modes = new iControl.LocalLBPersistenceMode[1];
modes[0] = iControl.LocalLBPersistenceMode.PERSISTENCE_MODE_UIE;
To create a persistence profile “foo” with a persistence mode of “PERSISTENCE_MODE_UIE”, you could do something like the following:
public void createPersistenceProfile() throws Exception
  String [] profile_names = new String[1];
  profile_names[0] = "foo";
  m_interfaces.getLocalLBProfilePersistence().create(profile_names, modes);
Hope this helps…
-Joe
Joe,
Your quick reply and the quality of the content was excellent. It is very much appreciated.
Mike Tan
Great, glad I could help!
