LocalLB.PoolMember. set_connection_limit
How can I set connection_limit for PoolMember using apache soap with java?
MemberConnectionLimit[][](array of array) does not support on apache soap.
Please help.
The short answer is that you can not.
Apache SOAP has not been actively worked on in many years (I believe since 2001). I would recommend going with Apache Axis as that has full support for multi-dimensional arrays. I also supports full client generation via WSDL4Java which makes development much easier.
With v9.2.2 of our SDK, we removed support for Apache SOAP just for this reason.
-Joe
Thank you.
Try it again using Axis.
