local variable within same irule on all events
Hello,
I’d like to use a local variable to log all event within a certain irule.
Since now I have done like this:
when CLIENT_ACCEPTED { set logdebug 1 if {$logdebug != 0} {log local0.info “Client Connected, IP: [IP::client_addr], pool [LB::server pool]”} }
when HTTP_REQUEST { set logdebug 1 if {$logdebug != 0} {log local0.info “Client IP IP: [IP::client_addr], host [HTTP::host]”} }
when LB_SELECTED { set logdebug 1 if {$logdebug != 0} {log local0.info “in LB_SELECTED, IP [IP::client_addr]:[TCP::client_port], node [LB::server addr], pool [LB::server pool]”} }
But I’d like to avoid global variable and have to set logdebug to 1 only once on the irule ? Is that possible ? maybe with "session add " on the CLIENT_ACCPTED event ?
Irule variables are tcp connection specific in scope , so you can set it once in CLIENT_ACCEPTED and will work for all events on that top connection.
How about using a static variable defined when the iRule initiates?
when RULE_INIT {
     set static::logdebug 1
Thank’s, therefore the right way to log in may case should be:
when CLIENT_ACCEPTED { set debug 1 if {$debug != 0} {log local0.info “Client Connected, IP: [IP::client_addr], pool [LB::server pool]”} }
when HTTP_REQUEST { if {$debug != 0} {log local0.info “Client IP IP: [IP::client_addr], host [HTTP::host]”} }
when LB_SELECTED { if {$debug != 0} {log local0.info “in LB_SELECTED, IP [IP::client_addr]:[TCP::client_port], node [LB::server addr], pool [LB::server pool]”} }
when LB_FAILED { if {$debug != 0} {log local0.info “in LB_FAILED, IP [IP::client_addr]:[TCP::client_port], node [LB::server addr], pool [LB::server pool]”} }
Can you try this?
when RULE_INIT {
    set static::debug 1
    set logdebug $static::debug
    if {$logdebug} {
        log local0.info "Client Connected, IP: [IP::client_addr], pool [LB::server pool]"
    if {$logdebug} {
        log local0.info "Client IP IP: [IP::client_addr], host [HTTP::host]"
when LB_SELECTED {
    if {$logdebug} {
        log local0.info "in LB_SELECTED, IP [IP::client_addr]:[TCP::client_port], node [LB::server addr], pool [LB::server pool]"
From my knowledge static variable are global therefore if you use it on other irule you will have issues ..
Personally I generally don’t tend to use static variables - they are too subject to unexpected change from other irules ‘accidentally’ initialising the same variable. Think variable ‘static::debug’ - what crimes have been committed against that?
I tend to use CLIENT_ACCEPTED to initialise my variables - the overhead is negligible.
RULE_INT sets global variable that’s ouf of my scope.
With caveat - except where variables are actually global in scope. Even then woul try to use session table if poss.
sorry, I missed the requirement.
Yes sorry I missed that too. Just do as iheartf5 mentions above. Set the local variable in the CLIENT_ACCEPTED event and it will then exist for all the other events for that particular connection.
No problem. It was out of the requirements because I think that if you set the variable, for log purpose, as a global one you have effect on all other irule where this variable is used and for me doesn’t make sense. Isn’t ?
If I may add, and to expand on IheartF5’s comments, global variables can be created anywhere and are indeed global to the entire device (other iRules, other VIPs, everything). There are good reasons to use global variables, but can also be troublesome if you’re not careful. Also, while you can technically create a global variable anywhere, if you create one outside of RULE_INIT, or try to write to one later, you’ll disable CMP.
All variables, other than global ones, are “connection-scoped”, meaning that they exist within the span of a single TCP connection. Because of this, you’re best bet is usually to create them at the absolutely lowest layer (the CLIENT_ACCEPTED event) where they’re guaranteed to exist everywhere else.
