Hi, My device is using only simple load balancer(no LTM license).Communication from outside to inside is good. However, it can not be determined from the packet statistics. Is it because there is no LTM license? Or is it a bug?
Which hardware & F5 OS device is using? Also License is necessary may be due to license. What shows in Network Map can you check in same path, login to f5 Main < local traffic < Network Map
This might be a silly question but are you sure this is from the active device?
