I’ve been looking for a way for use iControl to create the Local Traffic Policies introduced in 11.4, but I don’t see anything about these in the API. Am I missing something, or does this functionality not exist yet?
This is only available in the REST API, please see the following:
Introducing a RESTful interface for iControl DevCentral - An F5 Technical Community
REST User Guide DevCentral - An F5 Technical Community
Below is an example:
This creates a new policy that redirects to a different pool “p1” based on URI containing “servers” in the uri-path
POST https://192.168.1.75/mgmt/tm/ltm/policy?$expand=* (remeber to use the syntax from the manual including auth and content-type)
"kind": "tm:ltm:policy:policystate",
"name": "mynewpolicy",
"generation": 0,
"lastUpdatedMicros": 0,
"partition": "/Common/",
"controls": [
"forwarding"
"requires": [
"http"
"strategy": "all-match",
"rules": [
"kind": "tm:ltm:policy:rules:rulesstate",
"name": "mynewpolicy_rule",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/ltm/policy/mynewpolicy/rules/mynewpolicy_rule",
"ordinal": 1,
"actions": [
"kind": "tm:ltm:policy:rules:actions:actionsstate",
"name": "0",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/ltm/policy/mynewpolicy/rules/mynewpolicy_rule/actions/0",
"code": 0,
"forward": null,
"pool": "/Common/p1",
"port": 0,
"request": null,
"select": null,
"status": 0,
"vlanId": 0
"conditions": [
"kind": "tm:ltm:policy:rules:conditions:conditionsstate",
"name": "0",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/ltm/policy/mynewpolicy/rules/mynewpolicy_rule/conditions/0",
"caseInsensitive": null,
"contains": null,
"external": null,
"httpUri": null,
"index": 0,
"path": null,
"present": null,
"remote": null,
"request": null,
"values": [
"servers"
GET https://192.168.1.75/mgmt/tm/ltm/virtual/vip_ssl
Get the output and add the line marked below to add the policy and send it back as a PUT to modify the VIP.
PUT https://192.168.1.75/mgmt/tm/ltm/virtual/vip_ssl
(vip_ssl is the name of the vip, to add the policiy to the VIP)
"kind": "tm:ltm:virtual:virtualstate",
"name": "vip_ssl",
"generation": 0,
"selfLink": "https://localhost/mgmt/tm/ltm/virtual/vip_ssl",
"autoLasthop": "default",
"cmpEnabled": "yes",
"connectionLimit": 0,
"destination": "192.168.1.77:https",
"enabled": null,
"gtmScore": 0,
"ipProtocol": "tcp",
"mask": "255.255.255.255",
"mirror": "disabled",
"nat64": "disabled",
"pool": "p2",
"rateLimit": "disabled",
"rateLimitDstMask": 0,
"rateLimitMode": "object",
"rateLimitSrcMask": 0,
"policies": "mynewpolicy", <<<
"source": "0.0.0.0/0",
"sourceAddressTranslation": {
"type": "automap"
"sourcePort": "preserve",
"synCookieStatus": "not-activated",
"translateAddress": "enabled",
"translatePort": "enabled",
"vlansDisabled": null,
"vsIndex": 2,
"profilesReference": {
"link": "https://localhost/mgmt/tm/ltm/virtual/vip_ssl/profiles"
