Local Port Irule - Requiring IP Persistence
Hi All,
I have the below config that is running fine though I now want to specify different IP Persistence for each of the below pools. Current I have set on the VIP a Persistence of 3600seconds - Source Address Affinity
when CLIENT_ACCEPTED {
log local0. [TCP::local_port]
if { [TCP::local_port] == 80 } {pool pool-testesttest-sotl}
elseif { [TCP::local_port] == 17024 } {pool pool-anothertest-sotl}
elseif { [TCP::local_port] == 19012 } {pool pool-extratest-sotl}
If you’re running 9.x, check your iRule 9.x forum post (Click here). If you do need to do this in 4.x let me know.
Thanks,
Aaron
