Load Balance is not happening on pool members with two different service ports
Hi Team, We have issue is doing Loadbalence for the pool members. The below are the pool members and the traffic is going to only one server tcp port on both the server that is 15201. We have 2 irules 1 is URL redirect by adding uri /jde/owhtml and other irule is adding header. Please help me in resolving this issue.
- 172.30.50.160:15201
- 172.30.50.160:15202
- 172.30.50.161:15201
- 172.30.50.161:15202
Here is the config on VIP.
ltm virtual /Common/JDEPROD.corp.com_vs { description Replica_of_JDEPROD.corp_vs-172.30.23.45 destination /Common/172.30.23.53:80 ip-protocol tcp mask 255.255.255.255 pool /Common/JDEPROD.corp_pool profiles { /Common/http { } /Common/stream { } /Common/tcp { } } rules { /Common/jde_redirect /Common/jdeprod1_irule } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled
ltm pool JDEPROD_pool {
description JPEDPROD_ load-balancing-mode least-connections-member
members { JDNAJASP1:15201 { address 172.30.50.160 session monitor-enabled state up } JDNAJASP1:15202 { address 172.30.50.160 session monitor-enabled state up } JDNAJASP2:15201 { address 172.30.50.161 session monitor-enabled state up } JDNAJASP2:15202 { address 172.30.50.161 session monitor-enabled state up } } monitor JDEMonitor_New
ltm monitor http JDEMonitor_New {
adaptive disabled defaults-from http destination : interval 20 ip-dscp 0 recv EnterpriseOne recv-disable none send “GET /jde/index.jsp \r\n\r\n” time-until-up 0 timeout 61
IRULE
ltm rule jde_redirect {
when HTTP_REQUEST { if { [HTTP::uri] equals “/” } { HTTP::redirect “http://[HTTP::host]/jde/owhtml” }
ltm rule /Common/jdeprod1_irule { when HTTP_REQUEST { Disable STREAM processing for request (ingress) traffic STREAM::disable
Remove the Accept-Encoding header to disable server side compression
HTTP::header remove Accept-Encoding
Replace the incoming Host header to match what the server expects
HTTP::header replace Host "jdeprod1.corp.example.com:15201"
} when HTTP_RESPONSE { if { [HTTP::header exists Location] } { If this is a redirect response, replace with HTTP::header replace Location [string map {“jdeprod1.corp.example.com:15201” “jdeprod1.corp.example.com”} [HTTP::header Location]]
Use a STREAM expression to remap all object references in the payload (HTML body) with the external host name
STREAM::expression {@jdeprod1.corp.example.com:15201@jdeprod1.corp.example.com@}
STREAM::enable
} when LB_SELECTED { log local0. “URI [HTTP::uri] Client [IP::client_addr] [LB::server] selected.” } }
