Load Balancing with SIP Server
Hi, My BIG-IP LTM is not working with SIP server, please find below logs which i am getting in TCP dump. 10.84.95.103 is my Virtual IP and 10.84.87.70 is voice gateway from where request is coming, I am not able to see my Server Ip in TCP dump. Please help to resolve this issue.
17:06:26.508871 arp reply 10.84.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 17:06:42.028443 IP 10.84.87.70.19319 > 10.84.95.103.sip: S 4129144531:4129144531(0) win 4128 17:06:42.028468 IP 10.84.95.103.sip > 10.84.87.70.19319: R 0:0(0) ack 4129144532 win 0 17:06:52.912995 arp who-has 10.84.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 17:06:52.913022 arp reply 10.84.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown)
It is hard to tell from the above information what may be happening. Lets start with your configuration.
  1. Do you have a UDP virtual server listening on port 5060?
  2. Do you have a SIP profile attached?
  3. Does the SIP profile have the option Insert: via Header option selected?
  4. Is the virtual server using SNAT?
See SIP Profile from the manual for 11.2
You can get answer of your all query from below configuration :- ltm pool SIP-POOL { description “SIP POOL” members { INDMCCTCVP01P:sip { address 20.74.86.28 monitor min 1 of { Monitor_5060 } session monitor-enabled state up } INDMCCTCVP02P:sip { address 20.74.86.29 monitor min 1 of { Monitor_5060 } session monitor-enabled state up } INDMCCTCVP03P:sip { address 20.74.86.30 monitor min 1 of { Monitor_5060 } session monitor-enabled state up } INDMCCTCVP04P:sip { address 20.74.86.31 monitor min 1 of { Monitor_5060 } session monitor-enabled state up } } monitor SIP-Monitor
ltm virtual SIP_VIRTUAL { description “SIP VIRTUAL SERVER” destination 20.74.95.103:sip ip-protocol udp mask 255.255.255.255 persist { SIP-persistence { default yes } } pool SIP-POOL profiles { SIP-Profile { } SIP-UDP-profile { } } source 0.0.0.0/0 source-address-translation { pool SNAT-POOL type snat
ltm profile sip SIP-Profile { alg-enable disabled app-service none community none defaults-from sip dialog-aware enabled enable-sip-firewall no insert-record-route-header enabled insert-via-header enabled max-size 65535 secure-via-header disabled security disabled terminate-on-bye enabled user-via-header “SIP/2.0/UDP 20.74.95.103:5060” }
Please show tcpdump command you use.
[root@DB_LB_PRI:Active:In Sync]]0;DB_LB_PRI config tcpdump -i any host 10.74.95.103 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on any, link-type EN10MB (Ethernet), capture size 96 bytes 19:14:13.227126 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:14:13.227132 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:14:41.914629 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:14:41.914636 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:15:03.727405 IP 10.74.87.70.58464 > 10.74.95.103.sip: SIP, length: 393 19:15:11.427676 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:15:11.427684 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:15:41.145399 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:15:41.145407 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:16:09.221470 IP 10.74.87.70.58464 > 10.74.95.103.sip: SIP, length: 393 19:16:11.006977 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:16:11.006985 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:16:40.896259 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:16:40.896265 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:17:09.962243 arp who-has 10.74.95.103 (00:23:e9:7d:a6:07 (oui Unknown)) tell 0.0.0.0 19:17:09.962250 arp reply 10.74.95.103 is-at 00:23:e9:7d:a6:07 (oui Unknown) 19:17:14.713581 IP 10.74.87.70.58464 > 10.74.95.103.sip: SIP, length: 393
Please use tcpdump -i vlan_name host x.x.x.x and see if that works for you.
If any of the below posts have provided a solution to your issue, please indicate so by clicking the tick to the left of them. This gives feedback and recognition to the volunteers who responded to your issue :slight_smile:
