Load balancing with applications that don't like it
We have an application that occasionally makes a call to a web server through F5. The problem is when we disable a VS for patching / code update, application doesn’t handle the disabling of the server well and will throw an error unless the application is restarted.
Was told that an iRule might be my best bet so I’m trying to come up with an iRule that checks to see if the server is disabled and if so, closes the connection back to the application. Hoping this will create a more seamless failover to the secondary VS. Is there an iRule already created that does this?
(we don’t have persistance turned on, the second VS is at our DR site. We have 2 GTMs and 4 LTMs (2 redundant pairs, 1 at each datacenter).
Thanks in advance for the help.
can you try this?
[root@ve1023:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve1023:Active] config  b pool foo list
pool foo {
   monitor all http
   members 200.200.200.101:80 {}
[root@ve1023:Active] config  b rule myrule list
rule myrule {
   when CLIENT_ACCEPTED {
        log local0. "[IP::client_addr]:[TCP::client_port] > [IP::local_addr]:[TCP::local_port]"
        log local0. "\[active_members [LB::server pool]\]: [active_members [LB::server pool]]"
        if {[active_members [LB::server pool]] < 1} {
                TCP::close
[root@ve1023:Active] config  b pool foo|grep -i pool\ member
+-> POOL MEMBER foo/200.200.200.101:80   inactive,down
[root@centos251 ~] curl -I http://172.28.19.79
curl: (52) Empty reply from server
[root@ve1023:Active] config  tail -f /var/log/ltm
Dec  2 06:12:26 local/tmm notice tmm[23027]: 013e0001:5: Tcpdump starting bcast on :::0 from 127.1.1.1:55463
Dec  2 06:12:29 local/tmm info tmm[23027]: Rule myrule : 172.28.19.251:38310 > 172.28.19.79:80
Dec  2 06:12:29 local/tmm info tmm[23027]: Rule myrule : [active_members foo]: 0
[root@ve1023:Active] config  tcpdump -nni 0.0 port 80 and not host 200.200.200.101
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 108 bytes
06:12:29.387374 IP 172.28.19.251.38310 > 172.28.19.79.80: S 4233237129:4233237129(0) win 5840
06:12:29.387417 IP 172.28.19.79.80 > 172.28.19.251.38310: S 506930985:506930985(0) ack 4233237130 win 4380
06:12:29.388397 IP 172.28.19.251.38310 > 172.28.19.79.80: . ack 1 win 46
06:12:29.388471 IP 172.28.19.79.80 > 172.28.19.251.38310: F 1:1(0) ack 1 win 4380
06:12:29.388475 IP 172.28.19.251.38310 > 172.28.19.79.80: P 1:156(155) ack 1 win 46
06:12:29.389177 IP 172.28.19.251.38310 > 172.28.19.79.80: F 156:156(0) ack 2 win 46
06:12:29.389189 IP 172.28.19.79.80 > 172.28.19.251.38310: . ack 157 win 4535
Thanks, we’ll give it a shot. Thanks for the quick reply.
