load balancing to specific pool member
I have a questions and I thought a lot. but not solved clearly. would you help me?
One pool named pool_30 and two pool members 30.30.30.10(priority 10) & 30.30.30.20(priority 1)
my questions are below
  1. if pool member 30.20 down, traffic will go to 30.30. and 30.20 up, Regardless of priority, I want all traffic go to 30.30
  2. when pool member down, load balancing to pool another pool member have some delay. how can I solve?
I config iRule, confirm and have good idea. advice me thanks
when CLIENT_ACCEPTED { if {[LB::status pool pool_30 member 30.30.30.10 80] eq “up”} { log local0. “Active members are : 30.30.30.10 80” pool pool_30 member 30.30.30.10 80 } else { log local0. “Active members are : 30.30.30.20 80” pool pool_30 member 30.30.30.20 80 return } }
Hi Swjo,
you don’t need an iRule to create an Primary/Secondary pool member setup. Just use the Priority Group Activation feature in combination with the OneConnect feature (a Layer7 Virtual Server with HTTP profile is required).
OneConnect will force a LB decission on each single Web request and will then forward the individual request based on the current Priority Activation Group availability.
sol7208: Overview of the OneConnect profile: Content Switching
Configuring Load Balancing Pools: Specifying priority-based member activation
Cheers, Kai
