load balancing tftpd
First post - did try the search engine first though, so be kind !
Big-IP version 9.11 - trying to load balance tftpd across two Linux RHE servers.
Virtual is defined on a ‘SNATS’ vlan with SNAT Automap enabled.
two servers live on a different VLAN.
Googling found a suggestion for using a rule as follows:
when SERVER_CONNECTED {
listen {
proto UDP
timeout 5
bind [LINK::vlan_id] [IP::local_addr] [peer {UDP::client_port}]
server [peer {client_addr}] [peer {UDP::client_port}]
allow [IP::server_addr]
This does appear to be handling the translations, but things are still not working. Any known issues/caveats with tftpd ?
