Has anyone had any success load balancing print servers? We have two Windows 2003 print servers. I would like to load balance them behind the LTM. I have not had any luck. Can someone that has already done this help me out? What persistence do I need to use?
What the symptoms?
Here are two related threads with details on configuring the load balancing of MS print servers:
MS Print servers
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=25&tpage=1&view=topic&postid=29211
iRule to modify the client IP to Virtual Server IP
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=3048030522
Aaron
