Hi All
Has anyone configured load balancing for TrueSight Operations Management on the F5.
The load Balancing is only for its SNMP Adapter. what is happening is that the Application server is getting the requests but it is giving an error with the following details, /Program Files/BMC Software/TSIMAgent1/Agent/server/lib/perl/Convert/ASN1/_decode.pm line 58.)
This is my VS configuration
ltm virtual /tsom/vs_tsom {
destination /tsom/10.10.10.10:162
mask 255.255.255.255
pool /tsom/pool_tsom
profiles {
/Common/fastL4 { }
source 0.0.0.0/0
source-address-translation {
pool /tsom/snatpool_tsom
type snat
translate-address enabled
translate-port enabled
Any ideas or suggestion as to what may be causing the error on the server side.
